Problem Accessing Images From FileMaker DB through PHP(FX.PHP)
Hi
I am facing problem when accessing image from FileMaker Database.
First of all my software specifications:
Filemaker Server Advanced 7 (FileMaker 8 DB Hosted)
PHP Version: 4.3.3
FX.PHP 4.0.0
windows 2003 sever
When i access the image for a search result listing.
It is showing the image of 1st record and reapeats the image
of first record for the rest of records.
I am using image_proxy.php for accessing image records.
The code is like below:
<?php
include_once('fx/fx.php');
include_once('fx/image_proxy.php');
$fxob=new FX('192.168.10.8',80,'FMPro7','HTTP');
$fxob->setDBPassword('password','username');
$fxob->setDBData('DBName','Layout-web');
$dataArray=$fxob->FMFindAll();
foreach($dataArray[data] as $val){
$image=null;
$image="fx/image_proxy.php?
FXimage=".vignereEncryptURL($val['containerPicture'][0]);
echo '';
Please reply if u have any solution.
Also tell me if any other way available for accessing the image from DB.
Regards
Debabrata Pati.
  • 2 weeks later...
I'm sure you did this - but did you initialize a new 'key' for image_proxy.php
I was not able to get image proxy working perfectly in my PHP and FM 6 solution so I used an old work around - which will not work in FM 7 (I believe)???
cover
It is also been suggested to keep images separate from the FM database in a folder and access them that way.
In theory image_proxy is should work - but I am still waiting for someone to develop and easy function similar to the CDML way of getting images from container fields.
