Using double quotes in calculations
I'm looking to capture double quotes within a calculation for the purposes of producing a desired url
For example trying to capture:
http://www.xyz.com"abc"
How would you script this?
I can get to "http://www.xyz" but then I can't figure out how to capture the double quotes because they are inherent operators.
I would think it would look like: "http://www.xyz.com"&""" but that doesn't work and for obvious reasons. Is there a substitue symbol I should be using?
Forgive me - I'm not a programmer
Although I have now idea why you would want to put a quote behind a email address,
Try
HTH
Hi Lee and thank you. I'll try this tomorrow. Since you asked, I'll be more specific about my application.
I manage a sales team at an ISP. We sell the Internet component but often times this requires a 3rd party loop to get between our location and the end user's address. Therefore, I've put together a database of vendors addresses for my team's reference that allows them to submit quote requests to these various 3rd parties based on their addresses in relation to our network.
In doing so, I'm also using the USPS's address standardization dbase which is available via XML and various APIs. I downloaded their API and entered it into my browser to test it. It worked fine.
Here's the catch. Their required request (sent to them via a url) uses double quotes in the formula.
Therefore, when I was building the XML query, I couldn't figure out how to use Filemaker's syntax in the url calculation field to encapsulate the double quotes because double quotes are considered a parameter.
I believe your suggestion will work. Will try when I get into work tomorrow.
Thanks again,
Rick
In looking at this again, let me start by saying that the "" is telling FileMaker to treat this operator as a Text character, instead of an operator. If you were to do a search of the forum, for quotes, and calculations, etc., you would see that since version 7 was released, it has made it easier to deal with quotes and other operators.
In looking at the earlier posts, it isn't really clear to me what your real circumstances are, and how this needs to be applied.
So, I don't think that the previous post will work, and this is modified version that I also don't think will do it.
http://www.xyz.com """abc"""
I think this is what you are wanting,
"http://www.xyz.com" & """& "abc" & """
However, if you are Concatenating two fields, then here is is another way that may be easier.
Lets say you have Two existing Fields, and I'll call them [color:blue]URL and [color:blue]TAG for this demonstration.
[color:blue]URL = text field (has your data www.xyz.com)
[color:blue]TAG = text field (has your data abc)
New Field (Calculation, Text Result ) =
[color:blue]URL & """ & [color:blue]TAG & """
or shorten it to:
[color:blue]URL & Quote ( [color:blue]TAG )
Let me know if this doesn't help, and what where it breaks down.
Lee - thanks again
We're getting closer but not quite there.
Here's a better way of asking the question:
Can the following be produced in a url from a calculation?
http://"
(if it can, I can figure out how to reproduce elsewhere in the calculation)
NOTE:
"http://" & """ & """
returns
now if I can only get the language down to return a single "
Take your pick:
"http://"""
"http://""
"http://" & """
"http://%22"
hmm.... still nothing
Here is the actual url I am trying to produce from a calculation. Instead of using actual field references, I'll hard code it with a dummy address of:
6406 Ivy Lane
Greenbelt
MD
http://testing.shippingapis.com/ShippingAPITest.dll?API=Verify&XML=
6406 Ivy LaneGreenbeltMD
If you copy/paste this into a url, it will actually resolve (work). Therefore, question becomes how do you build a formula that will reproduce this. I would obviously be substituting the actual dummy data above with actual fields from my dbase.
The return data will yield:
<?xml version="1.0" ?>
6406 IVY LN
GREENBELT
MD
20770
1440
For some reason that url didn't copy/paste properly into this thread - perhaps too long - trying again
Alright, trying again, but removing http from front end
I am getting mighty confused here. Are you trying to produce a URL or create a XML document? Where is the result supposed to reside, and how do you plan on using it?
Inside Filemaker, a URL is nothing but a text string. I thought you asked for a calculation that returns this string:
http://"
Each one of the first three formulas above returns exactly that. The rest is a mystery to me.
My apologies
URL
The URL posts to the USPS site and returns a response (they are running an API) - I am delivering the data to that API via a URL they provided.
Because their URL request has double quotes in it, I needed to figure out how to repeat them in my formula.
I am using Filemaker Advanced 5.5
Created a button
[open URL, no dialogue;]
specify calculation:
ENTER code here necessary to output the following:
http://
Lee - correction
Filemaker Pro Advanced 8.5 (not 5.5)
I'm confused as to what you are really are needing.
Clarify version to be 5.5? as it makes a big difference in what you need for the quotes.
okay.
Next, the URL is usually a text field, not a calculation.
Post a sample of where you are going in the USPS site.
To keep it in tack, use the Globe Icon (URL Link) in the Reply so I can actually go to their site where you are talking.
Assuming you have the required data stored in fields with matching names, i.e.
UserID
Password
AddressID
Address1
Address2
City
etc...
your URL calculation needs to be along these lines:
"http://testing.shippingapis.com/ShippingAPITest.dll?API=Verify&XML=
& Quote ( UserID )
& "%20PASSWORD="
& Quote ( Password )
& Address1 & "" & Address2 & "" & City & "" etc. ...
Thanks Lee - I'll give this a shot when I return to work. The reason the url is a calculation is because of the nature of this request.
My dbases is loaded with customer provided addresses. Many times those addresses are provided to us incorrectly.
This calculation will pull the address, city, and state from each individual address within my dbase (when prompted) and push it to the USPS site where it will be run through their API. That data is pushed to them via http through a url with the data being requested.
Since each record is unique, a calculation must be performed to pull the data independently so that validation on the USPS site can be made and returned. The information returned is the correct spelling, punctuation, grammar and it adds the zip+4 data as well.
I can then webscrape that data back into my dbase if I wish or simply display it in a separate web viewer window.
I'll keep you posted on my progress. I very much appreciate you generosity in helping me through this process.
I think comment is on top of this better than me, but I will join in and help when I can.
Roger that
Comment/Lee - thank you
will advise on progress
I think I'm going to give up.
The 4 methods that Lee provided for reproducing double quotes withing a calculation just don't work on any sample calculation that I tried. Filemaker won't accept the language for me.
Here is a screen shot of what Common suggested along with the error code I'm receiving which states "The specified table can not be found" - referencing the highlighted portion of my user code below
& Quote (702[color:yellow][b][i]COGEN5515[/i][/b][/color])
& "%20PASSWORD="
& Quote ()
& Address1 & "" & Loop Quotes::Address 1 & " & "" & Loop Quotes::City & "" & "" & Loop Quotes::State & "" &Loop Quotes::Zip & &"" & & "
added code markup
Ok, I think I got it - stay tuned and thanks a million
Wow - 99.999% of the way there
Would you believe, everything is working properly execept 1 thing - the URL calculation isn't picking up the last character for some reason
Here is the the formula that "almost" works:
& """ & "702COGEN5515" & """
& "%20PASSWORD="
& ">" & Loop Quotes::Address 1 & "" & Loop Quotes::City & "" & Loop Quotes::State & "" & Loop Quotes::Zip & "" & "
" & "" Here is URL that works for testing purposes (what I'm trying to get the calculation to output). You just need to add http to the front of this. I'm leaving it off so that this doesn't get truncated in my post. ://testing.shippingapis.com/ShippingAPITest.dll?API=Verify&XML=
164 South Park St San Francisco CA
and here is the url its producing (note: only the last characeter is missing and that character is ">" ). Again, I dropped the "http" from the begginning of the url so that it would post correctly in the forum. :/testing.shippingapis.com/ShippingAPITest.dll?API=Verify&XML=
164%20South%20Park%20StSan%20FranciscoCA94107
Any ideas why this last character ">" won't show up??
added code markup
I addeda %20 to the end and this finally worked.
Thank you Lee
Thank you Common
I should have studied programming in school instead of PE :/
