April 2, 200718 yr Hi, I'm working on a script now that is supposed to look through all of my records, find those with a particular characteristic, duplicate those records, then copy and paste certain fields into other fields and clear the originally copied field. It looks like this...abbreviated. Show All records Perform Find Duplicate Record Copy [select; Forms::Field2] Paste [select; Forms::Field1] Clear [select; Forms::Field2] Enter Browse Mode The copy/paste/clear function works great. The problem is that it only performs the script on the first record it comes to that fulfills the Find requirements and I'd like it to go through and handle all records that meet the Find requirements. Any ideas? Thanks.
April 2, 200718 yr Hi j, It is really not clear to me what you are trying to accomplish. Why not start by telling us you are wanting to have happen. BTW, Why are't you using the Set Field Script step? Lee
April 2, 200718 yr Author Lee, This is going to be difficult to explain. A database run by one of our units has a record for each student who submits to us paperwork. Each student may send to us three installments of paperwork that are unrelated over time so the original designer set the records up to capture 3 different 'Submissions' of paperwork on each record. This is not a good design. What I wanted to do was to take, for example, John Doe who has 2 Submissions with us and break those into two records, one submission each. To do so, I would need to copy the info in Submission 2 into the Submission 1 fields. Once that is done I can get rid of the Submission 2 fields alltogether. Clear as mud, right? It's not easy to explain but there you have it.
April 2, 200718 yr since this will be used as a one time deal to seperate your data into a related table, try the following: Create the following Global fields gStudentID gSubmission1 gSubmission2 gSubmission3 Create a Submissions table if you have not already done so. For now, set the foreign key in the Submissions table (fkStudentID) to be an auto-calculation of gStudentID. Go to layout [ Students ] Show All Records [] Go to Record [First] Loop Set Field [ gStudentID; StudentID ] Set Field [ gSubmission1; Submission1 ] Set Field [ gSubmission2; Submission2 ] Set Field [ gSubmission3; Submission3 ] Go to layout [ Submissions ] If [ not IsEmpty ( gSubmission1 ) ] New Record [] Set Field [ Submissions::Submission; gSubmission1 ] End If If [ not IsEmpty ( gSubmission2 ) ] New Record [] Set Field [ Submissions::Submission; gSubmission2 ] End If If [ not IsEmpty ( gSubmission3 ) ] New Record [] Set Field [ Submissions::Submission; gSubmission3 ] End If Go to layout [ Original Layout ] Go to Record [ Next; Exit After Last ] End Loop Once successfully done and Verified, you can trash the global fields, remove the auto entry option in the fkStudentID, and delete the Submission fields in the Student table as well. Edited April 2, 200718 yr by Guest Clarification
