Help me for $$
I am a Mac user seeking assistance from a FileMaker guru that can aid in the completion of a simple project. I have created a temple for a specific fledgling business. The functionality of this template is incomplete as my knowledge for configuring the appropriate script is lacking. I do not seek a developer requiring a minimum of 20 hours at $150 per hour. I, however, can provide $500 for someone capable of doing 2-3 hours of work. If you feel you can help, contact me at [email protected] for details.
I am a Certified FileMaker 9 Developer located in Knoxville, TN. I own a company called the FM Developer’s Network. My rate is $95/hr; however, I do not have a minimum number of hours. I believe that clients will come back if they are treated fairly and I do not need to ‘force’ them to use my services.
If you still need FMP assistance, I’ve been doing full-time FileMaker development for over 10 years and can most likely lead you on the right path…
My number is 865-384-8353 and/or you can drop me a message at [email protected]...
Joe
Joe King
Certified FileMaker 7/8/9 Developer
President
865-384-8353
[email protected]
Joe, you should probably a) update your signature, but }:( Private topic the user.
Or use the email provided by the OP.
