Check repetition problem (help)
I'm burning my brains on something that has to be as easy as 123. But for some reason it doesn't work.
I'm working on a timesheet and want filemaker to mark if a person runs a second shift (on the same day). I have a calculation field which generates a unique id by combining the date and employer id. This number generated is unique, except when a double shift is run (date and employer id are the same, so same unique id is generated).
I then tried a self-joining relation, where this generated id is the relation. I figured a count or sum calculation would do the trick, no luck...
Please comment.
Why dont you add the shift number as part of the concatenation?
Shouldn't it be employee id? Anyway, a count of related records, e.g. Count ( selfjoin::EmployeeID ) should produce a correct result - after the current record is committed.
BTW, you do not need the calculation field: you can base the relationship directly on both fields. You can even eliminate self from the count, by defining the relationship as:
Timesheets::EmployeeID = Timesheets 2::EmployeeID
AND
Timesheets::Date = Timesheets 2::Date
AND
Timesheets::TimesheetID ≠ Timesheets 2::TimesheetID
I got something else... I think it works.
Created a self-joined relationship (named: duplicate shift check) with employer id and date as matches. Sorted by employer id (very important).
Then the following calculation field:
If ( duplicate shift check::double shift checksum = GetNthRecord(duplicate shift check::double shift checksum;Get(RecordNumber)- 1); 1; 0)
It does mark the second shift as '1', but I actually wanted both shifts to mark. So I will look into the submitted suggestions now.
Negative, it does mark 1, but on the wrong records...
This did the trick...
Count(duplicate shift check::)-1
Simple as 123 ;-)
Then with conditional formatting I marked yellow those > 0.
