Help with Omit Script
Good evening everyone.....
I have struggled with this one for a while and need some help.
I have figured the part below between the << >> now to get this to work.
When I am in the "Specify Find Request" dialog how do insert a previously set variable in the "criteria"?
I am putting $OrdNum in the criteria box and FMP Literally puts "$OrdNum" in the field instead of the variable.
This is driving me nuts becuase it seems like it should be so easy yet I cannot get it to work! I know I must be missing something basic.
Steve
My Fields are "pkOrdNum" and "PrdID"
I want to be to find all Records with a certain Order Number but Omit those with a PrdID that equals DISC>>
Steve
When run in Find mode, the Omit Record script step checks the "omit" option for the request.
Hi Vaughn,
I am sorry but I do not undestand your reply.
Steve
You can't use variable data in the Specify Find dialog. Instead you need to do it this way in your script:
Enter Find Mode
Set Field( field ; $variable )
Perform Find
I understand I can script as you state...
But how do I "Add a New Request"
So I can Find for "X"
but Omit "Y"
Steve
PS I have a work around but it is long and requires exporting to a temporary table and then finding and deleting the records I don;t wnat to display.
Enter Find Mode
Set Field( field ; $variable1 )
New Record Request
Set Field (Field; $variable2)
Omit
Perform Find
Thanks Lee.....
I was going to try that and then I talked myself out of it without trying...that was dumb of me!
Steve :
