If statement script problem, please help!
Hi All, I'm a bit of a newbie.
Here's my problem...
I have a one to many relationship between 2 tables, client and clients invoices.
There is an 'invoice type' field in the invoices table with drop down choices of 'Deposit' or 'Remainder'.
I also have a 'paid in full?' field with a drop down "yes / no" value list in the invoices table.
In the client table I have a 'deposit paid?' and 'Remainder paid?' fields both on a 'yes / no' value list
What I am trying to do is make an If statement script that says, If the invoice type is 'Deposit' then copy the 'paid in full' and paste it into the deposit paid field in the client table.
This is my script which works, but only if the invoice type is 'deposit', I need it to recognize the invoice type which is 'remainder' and do the same for the remainder paid field in the client table.
Link
Basically it's a set variable / set field script which checks the invoice type before replacing the field in the client table.
Is this the best way to do this? or is there an easier or more straight forward way to do it?
Any help much appreciated!
Why not use 'else', or write another If statement:
If [invoices::Invoice Type = " - package Remainder"]
etc.
Probably not. This:
doesn't go too well with this:
What you are saying is that if some invoice happens to be of type "Deposit", then this single invoice is going to determine the contents of the Deposit Paid field in the Clients table.
Also, if you do:
Commit Records
Go to Related Record […]
you will be taken to the FIRST related record in the Invoices table. If that invoice is not a deposit, then nothing happens. If it is, then other deposits are ignored.
I am not sure what exactly are you trying to accomplish here, but it seems like it would be better to use relationships and calculations to summarize the client's invoices, rather than a script.
I would add further that 'Deposit' and 'Remainder' suggests that you aren't utilizing a LineItems table. Payments, credits and refunds on an invoice should be held here. It sounds like you might be man-handling your solution when it could be more automatic with a few shifts in your structure.
There should be no need for script here at all. Would you be willing to post a clone of your file or provide a demo of the key components of it so we could get a better vision? :wink2:
Hi all,
Thanks for your responses, the reason I need to do this is for a 'monitoring' portal so I can see a list of all the unpaid deposits and remainders.
I am using a line items table with each invoice and have a separate pricelist table for creating new line sale items.
All I need is a fail safe way of marking certain invoices as a 'deposit' or 'remainder'. Purely for monitoring.
Currently I just have a text field within the invoice table which I use to mark any new invoice with the appropriate 'Deposit or 'remainder'
I could use calcs to determine the sale value and auto enter the deposit/remainder tags as my deposit amounts are nearly always around the £250 mark, the remainders always a greater monetary value than this.
But I feel it's not fail safe enough, which is why on creation of a new client record I had the field in there which auto enters as deposit and remainder unpaid until I mark it as paid.
Monitoring fields in the invoice table means they dont show up as unpaid until I create the invoice, but I need this info to show before I even create the invoice...
Any ideas?
Would you mind explaining how to write an if statement with two caveats?
ie: If Invoice type is 'Deposit, does one thing, if not do nothing
but if invoice is 'remainder' do this instead...
hope that makes sense!
I dont use if statements much!
