Web viewer portal problem
Hey guys, this is my first time here on FM Forums.
I have a problem with something.
Since I`ve written in swedish in FileMaer I`ll explain a bit what the problem is.
The posts on the portal is the jobs I`ve created today. I want to be able to click on the adress and then come to a layout with web viewer with google maps that shows the adress.
The problem is that if I klick on any of the adresses it always goes to the post that are currently " active "
lets say I stand on post 4 in the portal but I click on post 5, I still get the address of post 4.. I want it to understand which address I click on.
Any suggestions?:)
post-106852-0-21659300-1339606658_thumb.
Is your button in the portal row properly? What is your script for the button?
Go to related post, show only related posts from table _work with the layouy Web_viewer , thats where the data is.
It`s weird because it goes to the active post not the one Im clicking on..:)
I am not sure what is causing your issue. Also I cant really see anything from your screenshot.
Take a look at this demo
AddressMap.zip
thank you for the demo, it helped.
But if u see the screenshot its a red text above the portal, it says work that got registered << current date >> (today)
If I relate them by id like in the demo I cant se all the jobs that got registered today. just one..
Any solutions there?:)
I want it to look like the screenshot but work like the demo
I cant read your screenshot. It is too small. Plus your screenshot does not offer any look into your backend structure.
Well, I guess i can try explain it, I want to be able to get from the posts in the portal to a web viewer which displays the address of the post..
I can do like in the Demo but then I only see one post in the portal, and thats not good if I`ve created 5 posts.
Right now it doesnt work properly, If I " stand " on post 3 and click on post 5 it goes to post 3 in the web viewer. and if I stand on post 1 and click on post 2, it goes to post 1 in the web viewer..
dont really know how to explain it without working screenshots.
nvm, it works now, thanks for the help:)
