FileMaker 2026 Released
Sql Syntax Help
I need some help with executesql statements.
I am trying to compare a date in the Contracts table with a date stored in a global field in the BidR table.
I want to use executesql to get the date from the contracts table.
My statement is:
   ExecuteSql ( "SELECT estimatedawarddate_dt FROM contracts WHERE contracts.contractid_t = bidr.contractid_t";"";"")
The field "contractid_t" has the same value for both tables.  The returned value is"?" when the statement is executed.
Can anyone help with the syntax?
Also, how would I compare the date returned by sql with a filemaker date?
Thanks.
what is the field name of the global field in the
Bidr table?
My statement is:
Try
ExecuteSQL ( "
  FROM contracts
  WHERE contractid_t = ?
  " ; "" ; "" ; bidr::contractid_t // this must be a field reference in FileMaker format, since it's a parameter of ExecuteSQL()
Use the optional parameters, and the function will take care of any necessary type conversions, e.g. matching FM and SQL date formats, or implicitly quoting values when you query a text field.
eos,
Thanks for your reply, your example helped me understand how to use an optional parameter, but I still get the same result..."?".
I double checked the field data types, that they have actual dates in the fields, and the spelling of the table and field names.  It all seems syntactically correct.
I am not sure what else to check or do.
Wrap in EvaluationError() to see more details (error #)
