February 15, 201511 yr HI I am absolutely frustrated. I see greyed out areas to insert Audio in the Menu I am trying to insert audio into a container field. The same is true for PDF. I can drag any file into the container field and it resides there but It doesn't play or open. What is going on? I need to do this.
February 15, 201511 yr Select your container while in layout mode, then look to Inspector > Data tab at the very bottom. Check 'Optimize for interactive content.' :-)
