Problem creating a runtime solution
Am running filemaker Pro 13 Advanced, i used the developer utility dialog to create a runtime solution, after following all the necessary procedures, i click the create button but it gives the message "unable to find the runtime resources needed to create a runtime. please reinstall". Any possible solution would be appreciated.
Thanks.
Edited by Lee Smith
Change Title to sentence cap
To make a runtime FileMaker needs the folder 'FMI Runtime Resources'. It should be situated in the program folder. Is it possible that someone removed this?
​Yap, i have the FMI folder but it doesn't contain a "Runtime Resources" folder in it... i only has an images folder. What else can i do..?reinstall maybe..?
Yes. And - isn't that what the very first message said?
Similar Content
