What is best practice when it comes to importing data using JSON / ION? I usually use XSLT and FMPXMLRESULT for import
FM18P: What is best practice when it comes to importing data using JSON / ION? I usually use XSLT and FMPXMLRESULT for import, is there a similar way to do these imports of records into FileMaker?
FM19S consideration: I guess the simplest way is to write something in ECMA or Swift that outputs the portable array as FMPXMLRESULT? As pr example
curl -kL https://api.domain.tld > /opt/local/usecaseION2FMPXMLRESULT > /opt/FileMaker\ Server/Data/Documents/usecase.$(date).fmpxmlresult.xml
But then again FileMaker 19 Server does not allow for XML imports?
Edited by ggt667
Exporting XML files on the form FMPXMLRESULT works just fine PSOS FM19S linux, no need to worry about XML not being ported to FM19S Linux.
