Help with calculations for barcode data
Hi guys!
I am new to the forum and certainly not an expert on FM, I am currently implementing a Code128 barcode for some labels a client of our small business requires us.
Created a field that combines the data I need into one string of data for the barcode generator plugin of FM19 to use.
The issue is with two of those fields
First a date field:
I have a production date field  01/05/2021 and I need that data displayed without the separators (01052021)
Second a lot field:
I have a lot field formated M00045 and I need that data without the letters (00045) this I somewhat acomplished with the GetAsNumber calculation but it also removes the zeros that I need to keep as the number grows automatically.
Thanks in advance for your time and help, I really appreciate all input.
Filter ( table::date ; "0123456789")
 this will filter out slashes and the same for the LOT if you only want numbers only
Keep in mind that Filemaker accepts (and stores) dates with or without leading zeros. If user has entered the date as "1/5/2021" then filtering the field to keep digits only will result in "152021". If you want to be sure that the days and months are padded to 2 digits, use:
SerialIncrement ( "00" ; Day ( YourDatefield ) ) & SerialIncrement ( "00" ; Month ( YourDatefield ) ) & Year ( YourDatefield )
or shortly:
SerialIncrement ( "00000000" ; 10^6 * Day ( YourDatefield ) + 10^4 * Month ( YourDatefield ) + Year ( YourDatefield ) )
(I am assuming from your example that the format you want is DDMMYYYY.)
wow, I learned something I've never used Serial Increment that way, brilliant @comment I been using - Right ( "00" & day ( date_field ) ; 2 )
Welcome to version 7! :tongue3:
Thanks Ocean for the quick reply, your advice solved my issue of removing the unwanted separators and letters! 😀
or shortly:
Comment, is there a way to take the date and display it or store it showing DDMMYY?
In my original post I forgot to mention that in my barcode the date needs to show up in 6 digits.
I think FM lets you display 2 digit year dates on layout mode but stores them as 4 digit years for better data accuracy... is there a way to take the stored date and convert it to a 2 digit year via a calculation ?
Edited by JOSUAN
You can use:
SerialIncrement ( "00" ; Day ( YourDatefield ) ) & SerialIncrement ( "00" ; Month ( YourDatefield ) ) & Right ( Year ( YourDatefield ) ; 2 )
Or:
SerialIncrement ( "000000" ; 10^4 * Day ( YourDatefield ) + 10^2 * Month ( YourDatefield ) + Mod ( Year ( YourDatefield ) ; 100 ) )
22 hours ago, comment said:
You can use:
Or:
you are my hero, it worked flawlessly, thank you so much!😁
On 5/2/2021 at 2:04 AM, comment said:
You can use:
Or:
Lastly, I am trying to condtion this calculated fields to generate data only if related to the special client, but I find its only working in some cases.
Example:
Works
If ( c_client = "VIP" ; GetAsNumber ( Lot ) ; "" )
Doesn't work
If ( c_client = "VIP" ; SerialIncrement ( "00" ; Day ( ProductionDate ) ) & SerialIncrement ( "00" ; Month ( ProductionDate ) ) & Right ( Year ( ProductionDate ) ; 2 ) ; " " )
If ( c_client ="VIP" ; Right ( "0000000000" & LotQuantity ; 6 ) & ".00" ; " " )
Where do you put this calculation? Numeric field with a calculation? Calculation field? Set Field in Script? Others?
2 hours ago, JOSUAN said:
Doesn't work
"Doesn't work" is not a useful description. Can you post a simple file showing the problem - and preferably, nothing else? Something like the attached.
ddmmyy.fmp12
text fields with a calculation
Edited by JOSUAN
Ok, by doesn't work I meant that it does not perform the calculation leaving the field with no data or only with the zeros contained in " "
Thank you for the help/patience, I'll try to post the example file.
Your calculation is designed to return an empty result when the test  c_client = "VIP" is false. If you change it to return something recognizable, e.g.:
If ( c_client = "VIP" ; SerialIncrement ( "00" ; Day ( ProductionDate ) ) & SerialIncrement ( "00" ; Month ( ProductionDate ) ) & Right ( Year ( ProductionDate ) ; 2 ) ; "not VIP" )
you will be able to tell if the calculation was indeed not performed or it was performed but the test returned false.
If only zeros are returned, then the ProductionDate field does not contain a date.
Is there a reason you cannot use a calculation field? Do you need the user to be able to override the calculation's result?
