Help with parsing
Ok I've never made any calculations that had to parse before but i have alot to import and i definatly don't want to enter this stuff manually.
Does anyone know any good in-deapth resources for parsing data?
I'd start with the online help, look under text functions. Another good resource is FM Forums -- give us some examples and we can help you parse them.
Welp Here it is. I have a database that outputed two types of strings of data, one looks like this:
00 00 00 PROCUREMENT AND CONTRACTING REQUIREMENTS
and the other like this:
00 24 16.16 Scopes of Proposals (Multiple-Prime Contract)
I need to seperate the numbers in the beginning from the trade name at the end. I've contomplated just writing a calc to erase the numbers, and another to erase the text, would that be the easiest way? Or would a calc that sperated them be the best course of action, and if so, how the heck would you write something like that?
Hi
the Filter ( ) function that you had used is a good way to solve your problem, but you have to be sure that there aren't numbers into the trade name.
Try something like this, where 'raw' is your raw data field.
Let ( [ fl = Left ( Filter (raw ; "ABCDEFGHIJKLMNOPQRSTUVWXYZ"); 1 );    // First alpha letter returned
        lp = Position ( raw ; fl ; 1 ; 1 )                              // Position of first letter returned
        Left ( raw ; lp - 1 )                                            // Left value parsed
        Right ( raw ; Length ( raw ) - lp + 1 )                         // Right value parsed
If the strings of numbers are always fixed-length? If so then I'd just use the Left() function to separate them. Or I might Substitute() the white space between the number and the name with a paragraph symbol, the use GetValue() to grab the number and name.
