FileMaker 2026 Released
issues with null fields using conditionals (n00b question)
hi, I'm a few weeks into FM9 and I have a background as a PHP/MySQL developer and I'm finding the code a bit odd.
what I want to do in this context is have a field with three possible outcomes - if it is null one string, 0 another string, and anything >= 1 a final string. the code I'm (unsuccessfully) using is below. right now the only condition that doesn't work is 'Pending'.
thanks for any advice/help!
Case ( AttendNUM = 0 ; "Decline" ; AttendNUM ≥ 1 ; "Accept" ; "Pending")
Case(AttendNUM = "";one string;AttendNUM = 0;another string;final string)
The above returns one string if the value is null, another string if the value is 0 and final string if the value is anything else
hth
Phil
no dice...weird. I'll just figure out a work around.
your choices are either 0, Decline, or any number equal to or greater than 1, what would be the pending, less than 0?
This case statement would work if the number is greater than one
Case ( AttendNUM = 0 ; "Decline" ; AttendNUM = 1; "Accept"; "Pending")
HTH
I assume anything that has no value in AttenNum is pending:
Case (
not isempty (AttendNUM) and (AttendNUM)=0 ; "Decline" ; AttendNUM ≥ 1 ; "Accept" ; "Pending")
OR USE IT THIS WAY:
Case ( isempty (AttendNUM); "Pending"; AttendNUM ≥ 1 ; "Accept" ; "Decline")
I read the choices as Null, 0, >=1. No mention of non-integers between 0 and 1 and negative numbers.
Case(
IsEmpty(AttendNum); "Decline";
AttendNum = 0; "Pending";
AttendNum >=1; "Accept";
"Error")
isempty is what I was looking for. thanks!
