I need some help on a long calc...
in my database, I have 2 fields. 1 is a number, and the other a calc. Lets say in the number field i enter 21. In the calc. field, it will say "twenty one dollars". But if I enter in 100. It will say "one hundred and dollars". I am trying to get it to say "one hundred dollars" , or maybe even "One hundred and zero dollars" The Calc. I am using is below, NumberField is the field it is reading the numbers from. Any help?
Choose(Int(Mod(NumberField;10^12) / 10^11); ""; "One Hundred "; "Two
Hundred "; "Three Hundred "; "Four Hundred "; "Five Hundred "; "Six
Hundred "; "Seven Hundred "; "Eight Hundred "; "Nine Hundred ")
& Case(Int(Mod(NumberField;10^12) / 10^11)and Int(Mod(NumberField;10^10) / 10^9)>0>0;"and ";"")
If(Int(Mod(NumberField;10^11) / 10^10) = 1;
Choose(Int(Mod(NumberField;10^10) / 10^9); "Ten "; "Eleven "; "Twelve
"; "Thirteen "; "Fourteen "; "Fifteen "; "Sixteen "; "Seventeen ";
"Eighteen "; "Nineteen ");
Choose(Int(Mod(NumberField;10^11) / 10^10); ""; ""; "Twenty ";
"Thirty "; "Forty "; "Fifty "; "Sixty "; "Seventy "; "Eighty ";
"Ninety ")
Choose(Int(Mod(NumberField;10^10) / 10^9); ""; "One "; "Two "; "Three
"; "Four "; "Five "; "Six "; "Seven "; "Eight "; "Nine "))
Case(Int(Mod(NumberField;10^12)/10^9) and Int(Mod(NumberField;10^9) /
10^3); "Billion, "; Int(Mod(NumberField;10^12)/10^9);"Billion ";"")
Choose(Int(Mod(NumberField;10^9) / 10^8); ""; "One Hundred "; "Two
& Case(Int(Mod(NumberField;10^9) / 10^8)>0 and Int(Mod(NumberField;10^8) / 10^7)>0;"and ";"")
If(Int(Mod(NumberField;10^8) / 10^7) = 1;
Choose(Int(Mod(NumberField;10^7) / 10^6); "Ten "; "Eleven "; "Twelve
Choose(Int(Mod(NumberField;10^8) / 10^7); ""; ""; "Twenty "; "Thirty
"; "Forty "; "Fifty "; "Sixty "; "Seventy "; "Eighty "; "Ninety ")
Choose(Int(Mod(NumberField;10^7) / 10^6); ""; "One "; "Two "; "Three
Case(Int(Mod(NumberField;10^9)/10^6) and Int(Mod(NumberField;10^6) /
10^3); "Million, "; Int(Mod(NumberField;10^9)/10^6);"Million ";"")
Choose(Int(Mod(NumberField;10^6) / 10^5); ""; "One Hundred "; "Two
& Case(Int(Mod(NumberField;10^6) / 10^5)>0 and Int(Mod(NumberField;10^5) / 10^4)>0;"and ";"")
If(Int(Mod(NumberField;10^5) / 10^4) = 1;
Choose(Int(Mod(NumberField;10^4) / 10^3); "Ten "; "Eleven "; "Twelve
Choose(Int(Mod(NumberField;10^5) / 10^4); ""; ""; "Twenty "; "Thirty
Choose(Int(Mod(NumberField;10^4) / 10^3); ""; "One "; "Two "; "Three
Case(Int(Mod(NumberField;10^6)/10^3) and Int(Mod(NumberField;10^3) /10^0); "Thousand" & Case(Int(Mod(NumberField;10^3) / 100)=0;" and ";", "); Int(Mod(NumberField;10^6)/10^3);"Thousand ";"")
Choose(Int(Mod(NumberField;10^3) / 100); ""; "One Hundred "; "Two
& Case(Int(Mod(NumberField;10^3) / 100)>0 and Int(NumberField / 10)>0;"and ";"")
If(Int(Mod(NumberField;100) / 10) = 1;
Choose(Int(Mod(NumberField;10)); "Ten "; "Eleven "; "Twelve ";
Choose(Int(Mod(NumberField;100) / 10); ""; ""; "Twenty "; "Thirty ";
"Forty "; "Fifty "; "Sixty "; "Seventy "; "Eighty "; "Ninety ") &
Choose(Int(Mod(NumberField;10)); ""; "One "; "Two "; "Three "; "Four
"; "Five "; "Six "; "Seven "; "Eight "; "Nine ")) &
Case(Int(NumberField) > 1; "Dollars"; Int(NumberField) = 1; "Dollar";
If(Mod(NumberField; 1) and Int(NumberField);" and ";"")
If(Mod(Int(NumberField*10); 10) = 1;
Choose(Mod(Int(NumberField*100); 10); "Ten "; "Eleven "; "Twelve ";
Choose(Mod(Int(NumberField*10); 10); ""; ""; "Twenty "; "Thirty ";
Choose(Mod(Int(NumberField*100); 10); ""; "One "; "Two "; "Three ";
"Four "; "Five "; "Six "; "Seven "; "Eight "; "Nine ")) &
Case(Mod(NumberField; 1) > .01; "cents"; Mod(NumberField; 1) = .01; "cent";"")
See if this helps:
http://www.fmforums.com/forum/showtopic.php?tid/112852/tp/0/all/1/
Hi Tom,
They are using the Standard Edition of v9.
There is a file with a CF by The Shadow post to the thread comment pointed to.
Lee :
Good point, Lee. It's true that you can't actually create custom functions without FileMaker Advanced. However, I don't think any of the CFs for number-to-word that you'll find on the site I linked are recursive. I.e. you can easily modify them to use in a normal (non CF) calculation, FM Advanced not required.
At least some of them are. But the real question is whether they are any good. :eeek:
  • 1 month later...
Case(NumberIn = 0; ""; Let ( [FullNumber = GetAsNumber(numberin); Number = Int(FullNumber); len = Int(Log(Number)) + 1] ;
Case(len > 15; "Out of Range";
Currency = "EvalOnly"; Let([Hundred = Left(number; 1); TensOnes = Right(number; 2); TONum = GetAsNumber(TensOnes); Tens = Left(TensOnes; 1); Ones=If(TONum < 20; TensOnes; Right(TensOnes; 1))];
 Case(len = 3; Choose(hundred; ""; "One"; "Two"; "Three"; "Four "; "Five"; "Six"; "Seven"; "Eight"; "Nine") & " Hundred" & Case(TONum≠0;" ")) & Case(TONum > 19; Choose(tens; ""; ""; "Twenty"; "Thirty"; "Forty"; "Fifty"; "Sixty"; "Seventy"; "Eighty"; "Ninety") & Case(Ones ≠ 0; " "))
& Choose(ones; ""; "One"; "Two"; "Three"; "Four "; "Five"; "Six"; "Seven"; "Eight"; "Nine"; "Ten"; "Eleven"; "Twelve"; "Thirteen"; "Fourteen"; "Fifteen"; "Sixteen"; "Seventeen"; "Eighteen"; "Nineteen")
 If(len >3; Let([useLeft = Choose(Mod(len;  3);3; 1; 2); NewLen= 10 ^ (len - UseLeft); ThisValue = Div(number; NewLen); NewValue = Number - ThisValue * NewLen]; NumberInWords(ThisValue; "EvalOnly"; "None") & " " & Choose(Div(len - 1; 3); ""; "Thousand"; "Million"; "Billion"; "Trillion" ) & Case(NewValue ≠ 0;" " & NumberInWords(NewValue; ""; "None")));
NumberInWords(Number; "EvalOnly"; "None")) & Case(currency ≠ ""; " " & Currency) &  Case(DecimalCurr ≠ "None"; " and " & Let([Decimal = Int(100 * (fullnumber - number))]; If(Decimal = 0; "Zero"; NumberInWords(Decimal; "EvalOnly"; "None"))) & " " & DecimalCurr))))
I found this on here, somewhere...
