February 27, 200818 yr Newbies trying to sum a bunch of repeating entries of the same field. should be simple but I can't get it to work...
February 27, 200818 yr Author Newbies I think it is just a syntax thing. This is what I have been trying: Sum ( RepeatingHours Logged) my field is named Hours Logged How would I write that? Thanks
February 27, 200818 yr Its should just be Sum ( Hours Logged) if the field Hours Logged is a repeating field.
February 27, 200818 yr Is anything showing in the field, such as a question mark, or is it blank? Is there a second TO involved? Can you attach a sample of your file? Lee
February 27, 200818 yr BTW perhaps you should discuss why you are using repeating fields. It is not usually recommended for true data.
February 27, 200818 yr Author Newbies The first thing I tried was sum (Hours Logged) but it just gave me the hours for the entry I was on. Basically this is a log style database with two layout formats. One is descriptive where there are many aspects of a job listed for each job (page). Each page has many entries and represents one job. This generates a second layout that is a simple resume that lists the basics of all the jobs on one page. It is here that I want to display the sum of the total hours for the 'hours logged' from each job. Perhaps I am doing it all wrong. Probably...
February 27, 200818 yr It is not clear what you mean by "many entries". Does a job have many fields for this, or is it one repeating field, or do you just have multiple entries in a single field (separated by what?). BTW, neither one is a good way to approach this. You should have a table for Jobs and a related table for logging hours, where each log entry is a separate record.
February 27, 200818 yr Author Newbies This is my file: http://www.circusorange.com/Rigging_Journal.fp7
February 27, 200818 yr Change Total Hours into a Summary field (Total of Hours Logged). You need to change Hours Logged into a Number field for this.
