Export using XSLT problem
I am totally new in xslt.  I have the following xslt and I tried to export as xml.   I got an error.    "SAXParseException: invalid document structure".  Is there a problem in my structure?  What's the proper structure?
<?xml version='1.0' encoding='UTF-8' ?>
<xsl:stylesheet version='1.0'
  xmlns:xsl='http://www.w3.org/1999/XSL/Transform'
  xmlns:fm="http://www.filemaker.com/fmpdsoresult"
  exclude-result-prefixes="fm">
      <xsl:output version='1.0' encoding='UTF-8' indent='yes'
        method='xml' />
      <xsl:template match="/">
      <cityforcast>
            <xsl:for-each select="fm:FMPDSORESULT/fm:ROW">
                  <forcast>
                        <id><xsl:value-of select="./fm:ID” /></id>
                        <city><xsl:value-of select="./fm:City” /></city>
                        <temperature><xsl:value-of select="./fm:Temperature” /></temperature>
                        <humidity><xsl:value-of select="./fm:Humidity” /></humidity>
<windspeed><xsl:value-of select="./fm:Wind Speed” /></windspeed>
                        <winddirection><xsl:value-of select="./fm:Wind Direction” /></winddirection>
                        <clouds><xsl:value-of select="./fm:Clouds” /></clouds>
                  </forcast>
            </xsl:for-each>
      </cityforcast>
      </xsl:template>
</xsl:stylesheet>
Weather.fmp12
I see two problems here:
1. Your stylesheet uses the right quotation mark character (a.k.a. a "smart" or "curly" quote) where a regular quotation mark is required; for example in line 23, after "fm:ID":
and in 6 more places.
Lesson: use a text editor, not a word processor, to create and edit XML/XSLT documents.
2. Two of your fields have spaces in their names. This is allowed (though not recommended) in Filemaker, but when you export as XML using the FMPDSORESULT  grammar, Filemaker will replace the spaces with underscore characters because XML element names cannot contain spaces and the expression:
is invalid XSLT syntax. It will work if you change it to:
<xsl:value-of select="./fm:Wind_Speed" />
This is one of the reasons why the FMPXMLRESULT grammar is preferable; you do not depend on your field names - most importantly, you can rename your fields without affecting your stylesheet.
Similar Content
