Looking for FM7 "Project Management" solution
Anyone know of a FM7 Project Management solution?
Bob...
Bob:
The best place to start would be to look at Business Tracker and see how close that comes to your needs; then you can narrow down your requirements. After all, "project management" is at the core of most FileMaker solutions. Business Tracker can be found at:
http://www.excelisys.com/services/fmp7/business_tracker.htm
-Stanley
Have you looked at the sample files that come with FM7? Task Management looks like it might work.
