Having Problem here .... need help
Hi guys, i have a problem here. Why i can't show my Shockwave flash object pointed by using web viewer in the web. The database is hosted by FMS A9 using IWP.
  • 4 weeks later...
You need to have your web view pointing to a web address on the internet where you can host your shockwave file. It wont work if its stored locally the way it would work on a stand alone workstation.
Guest
This topic is now closed to further replies.
