March 11, 201412 yr Hi all After installing FMS 13 Windows 7 Professional 64 Odbc SQL Client 11 Im having some problems with schedule scripts that used to run before on FMS 12 very well Its not every time but some times the scripts start and in the admin Console we can see the status -> running and they don't finish and after 1 hour i have to restart FMS 13. Some times it works well four 3 our 4 hours then they start hanging again. And as I said before they work perfect in FMS12 Any Help please.
March 12, 201412 yr Author Help Please Still can't find a reason for Filemaker Server, to Keep hanging schedule scripts ??
March 12, 201412 yr I can't help you but wanted to let you know we've also had this same problem several times and are looking for a resolution. Our server scheduled script has been setup to abort after 5 mins. So after 5 mins, it gets Status "Time limit exceeded" but the "Server 13.01" client remains and we can't disconnect it. At the same time, the elapsed time per call goes up to 5 million which freezes FileMaker for all clients. The only way out is to kick out all users and reboot the server itself. It happens randomly as well. This script also ran fine in FMS12 and we've tried everything to trap the problem. Do you have the time limit set on your script to stop it? Do you see any performance issues when the script is runninghung? Good Luck!
March 12, 201412 yr Any scripting errors reported in the server event log? what are the machine specs?
March 12, 201412 yr Author Hi JKrier Hi Wim Server Intel ® Core TM i7 CPU 920 2.67 GHZ 2.67 Ghz Ram: 6GB 64 Bits Windows 7 Professinal Service Pack 1 64 Bits Dedicated: Filemaker Server 13 12 Web User 3 FileMaker Pro User 1 Filemaker Pro Advanced I Have a time limit and it reaches the time, The only error report is that it reached the time limit and thats it And at the admin console you only see status Running after 1 hour they all the scripts are running and none finish. And what is really interesting is that none off these 15 script had problems before FMS12 The only time i manage to make them work for 3 ou 4 hours is when I don't have more then 2 scripts fire at the same Hour. P.s The only thing that i found is that the scripts that hang are the ones that have ODBC connections ! But still no Luck
March 13, 201412 yr Author Hi Wim and JKrier Problem Solved its Because of the SQL Server Native Client Driver 11 I Have an SQL Server 2012 and I did Upgrade the Client Driver to Version 11 (2011.110.2100.60) Filemaker says in the technical Sheet that in SQL 2012 with SQL Server Native Client Driver 11 ready But I Found out that this was the problem because i Installed the old driver 10.0 (2009.100.1600.01) back again. And all scheduled scripts are running Normaly Thanks again
June 16, 201411 yr I'm going to revive this topic as I'm now having a similar issue with a client machine. Server side scripts that used to run fine on FMS11 (we skipped 12) are now occasionally failing to properly terminate on server. The script itself is done, I check the records and they have all been properly updated as required, but the script client stays running at 100% CPU on server which eventually fires off a warning. The only solution we have is to terminate the script after a period of minutes but this is far from ideal. The script while still connected as server client, has no stats so it's not really doing anything, it's just not closing itself when its done. However this leaves CPU at 100% which locks up all other users. If I manually disconnect the server client it goes back to normal. None of the scripts or databases use ODBC/SQL at all , it's all native FM. I have wondered if the shutdown scripts attached to the files are preventing the server from closing, but I've never seen this as an issue before and the fact it works sometimes but not others seems weird. Specs: Virtualised environment 4gb Ram FMS 13.0v2 Intel Xeon CPU-E7 2850 @ 2ghz Windows Server 2008 R2 Standard 64bit Has anyone come across this before? Any ideas? This is happening on 2 different virtual machines (both with same specs). Any suggestions of things to try?
June 17, 201411 yr No errors in the FMS event log (scripting errors or other) Make sure that any and all opening and closing scripts are shortcutted on server, just to make sure these are not an issue. Other than that: build in some internal logging in the script so that you can verify where they are in the process and at what times. That should help drill down to where the issue is.
July 4, 201411 yr Just me 2 cents on this but I had the very same problem. Fms12 was fine moved to fms13 and scripts would hang and kill the whole fms engine. I run a batch of scripts in multiple files every 3 minutes and they would run fine for hours or days and then Randomly lock up and kill the fms server. My solution was to deploy a vm client on the server with another fms instance using my developer server license and then Hosted a single fmp12 file that then ran the ots in the main files hosted on the host machine. I run a single ots every 3 minutes on the vm server file that opens all the files on the main host and run the real ots script in each of the main files sequentially. Been running for 2 months without a problem now.
