FMS 13.0v2 Admin Console Problems
HI,
I just updated to FMS 13.0v2 and the admin console is having problems. No files or clients are listed on the Activity page. Schedules are not visible either. Files are being served properly. However it's not possible to edit a schedule. Oddly, the Close All command and Open All seem to work and the results can be seen in the Log. I've restarted the server machine. No change. Is anyone else having these problems?
Rick
  • 4 weeks later...
I am having this exact problem.  I cannot find a solution for it either.  Did you figure anything out?
I ran the updater again. Solved the problem.
Hi Rick,
I've encountered the same issue! How did you rerun the updater? When I try to run the updater again, it says the corrsponding program cannot be found which indicates that FileMaker already knows its been patched to version 2.
Did you uninstall the first patch?
Jalz
I simply ran the updater again. No error messages... nothing unusual.
