Problem installing RemoteScripter 1.82 on FMSA15 WebDirect
I'm not sure what I'm doing wrong but when I check the version of the RemoteScripter 1.82 plugin from WebDirect client browser, I get the "?".
The FMSA15 is installed on OSX El Capitan, inside FileMaker Server/Web Publishing/Publishing-Engine/wpc/Plugins. Restarted the server.
I wrote a script that registers the plugin and I invoke the registration from the WebDirect client browser. And what I get is "?" from Version, Error or License Info check.
Can someone help me? THanks.
Remotescripter 1.82 on FMSA15 must be installed on FileMaker Server/Web Publishing/Publishing-Engine/cwpc/Plugins.
That is indeed the correct path. Are you still having issues getting the plugin to work?
