Business Tracker and IWP problem!
Computer: eMac
OS: Panther 10.3
IP: Static
I downloaded Business Tracker from Filemaker website, and enabled Instant Web Publishing.
But when I go to my other PC and launched it from IE, all the buttons and functions are screwed up, It's unusable. At the time I thought it was a Windows issue, but when I went home and tried to use it at home with my G4, same problems. Following are some of the problems:
- Home page is the catalog page instead of the main home page.
- "Return to Products" button disappears.
- Can't log out, log out creates red "x"s and sometimes crashes network.
- All buttons on the top that should read "Home, Companies, Contacts, Invoices, Products, Reports, Preferences" becomes all "Home".
- Can't create new entries.
FileMaker Version: 7
Platform: Mac OS X Panther
In the startup script there is a part that detects that you are a web user that brings you to another part of the application:
If[PatternCount ( Get(ApplicationVersion) ; "Web" )]
The same here: these script goes only to the return to products if it is not on the web: not PatternCount ( Get(ApplicationVersion) ; "Web" ). The button is an unstored: Case(not PatternCount ( Get(ApplicationVersion) ; "Web" ); gGraphics[10])
Koen
