Help!! Need work-around for guest log-in
I'm trying to teach myself about permissions/groups and I mistakenly set my file to auto-open with the guest account, and now I have no way to modify anything. Is there a way to re-login to the file or re-set the permissions? Right now I have no access to layout mode or script-maker. I scoured the online help, and came up with nothing. I tried saving a copy, but my copy did the same thing. HELP! confused.gif
Hold down the option key as you open the file and you'll get prompted for an account. (Shift key on Windows).
Mahalo!
