Fliemaker 7 has problems displaying stuff?
Has anyone noticed a few weird glitches on layouts?
Like,
1. a portal list that is white on a white background with 0 point sized lines displays periodic thin grey lines every two or three portal rows. When you change the colour to a dark colour it is kind of alright but still hard to disguise what look like lines.
2. When you select a portal line and then not select it leaves a line across the bottom of what you pressed without refreshing.
3. When you have modifiable fields (Behaviour set to input and view on find and browse modes) - click and hold on the screen somewhere it highlights all the bounding box edges to fields that you can enter data into. When you let go, it doesn't refresh the display like in problem 2.
