Filemaker Pro 7 problem
I am running FM Pro 7 in Windows XP. I have recently encountered a problem. The ctl+shift+d shortcut no longer brings up the define database window. I can still select it from the menu, but I can't bring it up with the key combination.
Has anyone else encountered and fixed this?
what group of keys would you use for ungrouping of objects? If it isn't CTRL+SHIFT+R then it's because you are used to FileMaker 5 and 5.5 shortcuts as apposed to FileMaker 6 and 7.
I hope this helps
