need help -- assigning records to committees for review
I have a table of job candidates, which will need to be assigned to committees for review.
There are 6 committees.
In general, the assignments can be completely arbitrary.
candidate 1--committee 1
candidate 2--committee 2
3 - 3
4 - 4
5 - 5
6 - 6
7 - 1
8 - 2
9 - 3
. etc.
That would be easy enough I guess.. but, here's the monkey wrench. My boss will need to predesignate some of the candidates in one way or another. He may say, designate candidate 23 to committee 4
or he may say, do NOT give candidate 24 to committee 5
So, I'd like a way to allow for these manual per-candidate rules to be allowed for, WHILE at the same time, in the end, having distributed an equal (or as close as possible to equal) # of candidates to each committee.
so far,
I have the following tables:
CANDIDATE
COMMITTEE
COMMITTEE_ASSIGNMENT
I'm thinking that it is easy enough to manually assign committee assignments for instances where my boss tells me:
or do NOT give candidate 24 to committee 5
BUT.. how do I make is so that the arbitrary assignments, which are scripted, should compare all the assignments to the 6 committees so that it keeps them all at an even level ?
I'm lost about how to approach this. Could anyone offer any advice ? thanks ;)
