Help with Print as PDF script.
Just as a disclaimer I'm a rookie working with Filemaker which I'm sure will be made clear in the post. I'm having problems with the container field quality after saving as a PDF. I have run into the problem with other programs as well so I realize it is not Filemaker's doing but I am trying to find a workaround for it. The issue is that I've been using 'Save As PDF' in a script and it worked out great until I noticed the poor quality. With "Save as" I was able to define a file path and name relative to the computer in use but I am not seeing a way to do this with the Print as PDF command in a script. I realize I can universially change the output path and file name when printing but these need to be specific to which Filemaker file was in use as the exported file is being used in Visual Basic script later. Any help would be appreciated. Thanks!
