How to fix Port Forwarding issue when installing Zulu
When installing Zulu you may get an error that web server forwarding did not work and Zulu is only available on port 42424 instead of port 80.   I spoke with 360Works support and they are aware of the issue.   The workaround solution is to install MirrorSync on your server.  MirrorSync and Zulu use the same application backend.  The MirrorSync installer will correctly setup the port forwarding.   You only need to install MirrorSync.  You do not need to configure it.  Once you have installed MirrorSync, run the Zulu installer again and it will complete and you will be able to access Zulu over port 80.
  • 1 year later...
Any Idea what I should do if I have the same problem with MirrorSync?  it configured itself to 42424 as well !
FYI: I uninstalled Zulu, installed mirror sync, re-intalled Zulu
Both are set to port 42424 instead of port 80
IIS v7 on Windows Server 2012 r2
Hi Johnre,
You can manually create the redirect rule. Instructions for doing so can be found here.
Thanks so much I swear I thought I had gone through all the documentation  on zulu  :-p
apparently not
Similar Content
