Scribe 4.03 Problem writing images to Excel
I modified an old script from a solution that exports rows of text fields with 1 image per row to xlsx. I don't know what version of the plugin was deployed with that solution, but images don't work when done with the older $result = ScribeDocWriteValue () or the newer script step. The plugin works without any errors but when opening the file I get "We found a problem with some content...Do you want to to try to recover as much as we can?" The resulting file is only 10K, whereas the image sizes vary from 200 - 600k, so it appears that the images are not being embedded.
I'm testing with Scribe 4.03 and FMPA 16.0.5.
-jb
Edited by jbsherry
