need your help guys filemaker problem
hi folks, this is my problem i bought filemaker pro 7 but the cd was sat on by my wife....(long story)... and it broke luckily i saved the license key now i just formated my pc and i don't know where to get a copy of the filemaker pro installation files do you guys know where i can download one thanks a lot... i know that you guys will reach out to help me.
and another thing if i download the trial at the filemaker site will my license key work with the trial version?. thanks again.
Not believable. I suspect you and anybody that helps you with this will be kicked off the forum. If your story is legitimate, you can go to your retailer or FileMaker Inc.
I suggest you talk to FileMaker Corporate. If they believe your story, then cool, they can help you. I think legally they should be the only ones to do it.
Guest
This topic is now closed to further replies.
