help to sort fields when defining fields
In FMP 6, you can start the name of your fields with an underscore "_" and they will sort to the bottom of the list when you do a "Sort by Name". However, in FMP7, these fields sort to the top with a name sort.
eg.
_DateCreate
_DateModify
_NameCreate
_NameModify
_g_number
_g_text
afield
anotherfield
What character can be used to make the fields go to the bottom of the list?
I don't want users to get confused if they see a bunch of developer fields at the top of the list.
These appear to be Developer fields, so just prepend z or zc to them. For example:
zc_createdDate, zc_createdName, zc_modifiedDate, zc_modifiedName
(as per the Core Development Standards). Use a divider in your fields table, something like
Z ----- DEVELOPER FIELDS -----
