Double-Clicking Problems
I'm running FM 7 on Mac 10.2.8 and can't double-click to move field names or functions; e.g., in the "Specify Calculation" window, after selecting a function from the list, double-clicking my mouse does not move the function to the dialog box, I have to type the function in the box, and ditto for the field names. Thanks.
Do you have the same problems in other programs, or just FM? Check your mouse double-click speed.
The problem is only in FM. My co-worker is running FM 7 on the same platform with no problems. I think I'll try re-installing.
I'm running 10.3.7, so I don't know about 10.2.8 (I'm actually seeing a little flakiness in Layout mode now; Option-dragging has to be really held down good or it doesn't duplicate; this started with 10.3.7). This is the first I've heard of your problem. Did you update to 7.0v3? Because earlier versions, especially the first, were a little buggy.
