Possible font problem crashing FMP7
In the process of trying to resolve a font-related issue for another app, it appears that I may have disabled a font that FM needs. I'm not certain about this but am trying to eliminate possibilities in a methodical fashion. Does anyone know of technical documents detailing FileMaker's requirement in this regard or have any experience with this type of problem?
Thanks - JAY
Fonts have to be installed in FileMaker in order to be used.
Open up Font Book (it is in the Utility folder) and check to see if the Font is available or disabled.
HTH
Thanks for your reply, Lee. I guess I didn't make that very clear. What I meant to say is that, IF I disabled a font(s) that FM needs, I don't have any idea which one(s) it might be.
What do you mean by, "Fonts have to be installed in FM in order to be used"? - that the FM installer checks for and adds fonts if necessary? If this is the case, I'd like to find out which ones are included.
JAY
