Problem with script, to copy portal records
I am new to this forum, and could use some help with a script.
I have found this script on this forum and adjusted it.
The script is working almost fine, but i have a problem with the portal
rows.
Only the first row from the portal is copied and the others not.
The reason that i want to copy is that i don't want to type the data twice.
I have a screenprint from the script attached.
Frans
Script copy record with portal.doc
I have solved the problem with the script see below, but now i have another question.
I try to perform the script from a layout (with a button) to copy the entries from the portal
to another portal in an external filemaker file.
The script works but i cannot open a new record in the external file.
I have tried it also with an "perform script" in the original script then he opens
a new record but i think that the variables are empty.
Has someone a clue how i can handle this
Frans
  • If [ Verkoopopdrachten::FactuurID ]
  • Set Variable [ $FactuurID; Value:Get(RecordNumber) ]
  • Show Custom Dialog [ Title: "Vrachtkosten aanmaken"; Message: "U gaat nu een kopie maken van deze Factuur om de vrachtkosten te declareren, wilt u dit"; Buttons: “Cancel”, “OK” ]
  • If [ Get (LastMessageChoice)=1 ]
  • Exit Script [ ]
  • End If
  • Go to Related Record [ From table: “Verkoopopdrachten”; Using layout: <Current Layout> ] [ Show only related records; Match found set ]
  • Duplicate Record/Request
  • Go to Record/Request/Page [ $FactuurID ] [ No dialog ]
  • Loop
  • Set Variable [ $productitemnummers; Value:Artikelen::Productitemnummer ]
  • Set Variable [ $Beschrijvings; Value:Artikelen::Beschrijving ]
  • Set Variable [ $Hoeveelheids; Value:Artikelen::Hoeveelheid ]
  • Set Variable [ $Valutas; Value:Artikelen::Valuta ]
  • Go to Record/Request/Page [ Last ]
  • Go to Layout [ “Formulierweergave” (Verkoopopdrachten) ]
  • Set Field [ Verkoopopdrachten::Formnaam; "Vrachtkosten" ]
  • Set Field [ Verkoopopdrachten::Verzendingsstatus; "Vrachtkosten" ]
  • Set Field [ Artikelen::Productitemnummer; $Productitemnummers ]
  • Set Field [ Artikelen::Beschrijving; $Beschrijvings ]
  • Set Field [ Artikelen::Hoeveelheid; $Hoeveelheids ]
  • Set Field [ Artikelen::Valuta; $Valutas ]
  • // Duplicate Record/Request
  • Go to Portal Row [ Select; Next; Exit after last ]
  • End Loop
  • Delete Portal Row [ No dialog ]
  • End If
