Need help regarding httppost using Semaphore SMS Gateway
Hello, good afternoon!
I'm from the Philippines and I really need help here regarding how to send SMS using Semaphore. Semaphore is an alternative for Twilio. I use Semaphore since this is a SMS Gateway for Philippines and it's every cheap as well.
Here's is my script using Insert from URL:
"httppost://api.semaphore.co/api/v4/messages?apikey={{KEY_REDACTED}}" & "&number"=SendMessage::mobileno & "&message"=SendMessage::textmessage
When I try to click the "Send" button that I created, it always give me an error (see the image below).
Hope someone can help me. Thanks!
  • 1 year later...
Hi Tondats,
hope you figured it out! Since your post is very old, I'm mostly writing to ask a moderator, who prescreen this message, to remove the api key in your original message.
If anyone else reads this, I'll do a shameless plug: consider using engageSPARK (I work there): https://www.engagespark.com/developerENGAGE-philippines
We're often told that my colleague from customer support are friendly and skilled, so I'm confident they'll get you through such troubles. :
Best,
Murat
