Simple layout problem
I can't seem to discover how to make text entry fields not print out with horizontal lines in them along with the text entered.
Silly question, I know, but I can't seem to solve this problem on my own
Thank a bunch for your help
Manca
Hi, Manca! Probably the baselines are visible by default. You should be able to go to layout mode, select the fields you want to change, go to the FORMAT menu, select FIELD BORDERS, and see if the BASELINES option is checked. If it's not baselines, it might just be the bottom line of the field box also accessible from that same page.
Hope this helps!
--ST
Hmm... now that I think about it, maybe it's just the Underline text style. In layout mode, try clicking on the field and go to the FORMAT menu and see if the STYLE shows UNDERLINE or not. That's even an easier fix if that's it.
--ST
