Problem with Å Ä Ö in web viewer
Hi!
I recently started to work with filemaker and so far I'm really impressed. But a problem that i can't really solve showed up. I followed the guide at http://fmcollective.com/?p=43 which describes how to insert only the map part of google maps (not the whole webpage) in filemaker using web viewer. I create the 2 php files i needed, put them on my webpage and then directed the custom webadress feature to this location. But now to the problem.
If my adresses in my databas contaions å ä ö it doesn't work. I've tried to figure out where the problem lies. Is it the charset of the php files or webbrowser but i think it has something to do with the web viewer feature of filemaker. Do u know?
if you simply have the web viewer load the google maps page, does it still fail with addresses containing "å ä ö" ?
