FMP 8.5 LEOPARD AND PRINTERS PROBLEMS
fmp 8.5 crash as soon as try to get the printer setting dialog or the printer dialog, the solutions is in preview situations.
Hw and Sw:
customer:
12 clients fmp8.5
leopard V2
Macintel (differents models)
server Fmp8.v4
P4 win server 2003
Solutions:
developed with Fmp 8.5
the solutions have to print
(A3) few records, every record have 4 containers contains 4 pdf image 1.2 Mb each, 3 field with 100 repetitions eah.
How i solved the problem:
using a mac and the "old" tiger 10.4.11
I tested in every way to solve the problem, only changing the OS X get me the result.
FileMaker 8.5 will not work on Leopard. They are suppose to come out with a patch.
For more information, read the numerous post about Leopard on this Forum, or at FMI site.
Search for [color:blue]+Leopard +FileMaker (use the pluses as shown) and you will find plenty of reading material.
HTH
