XP Compatibility Problem
I have a runtime program in Kiosk mode. A Setup was created using Setup Factory which (according to Indigo Rose) is compatible with the XP System. Problem - program will not start after it has been installed. It works fine on Win95 thru ME. Question - is this a FMP5 compatibility problem? The problem was brought to my attention when someone install the program on their new Compaq having the XP System (I'm using Win98).
Thanks in advance for your help,
Stan
