Difference records displayed in FM Pro Advanced 15 & webdirect
Hi everyone,
The problem I met is about record set is difference between the FM Pro 15 and it behaves at webdirect.
Here is the scenario :
Table : Contract, Salesperson, User
Relationship:
         User  <--[pk]----user_id----[fk]--> Salesperson
         Contract <-[fk]----sales_id----[pk]--> Salesperson
Privilege set :
        [Manager] - For record, table "Contract" (view) is limited to Salesperson::dept = $$DEPT
                 For layout, view access is allowed
        [Salesperson] - For record, table "Contract" (view) is limited to Salesperson::user_id = $$USER_ID
Flow:
    1) Once login-ed in, the script is triggered to load certain users' info. to global variables(e.g $$DEPT, $$USER_ID) by using the Get(Accountname) and table User
    2) After entering the layout which load the contract data, records showed should be limited according to privilege set
Problem is I could have the expected result at FM Pro 15 but not at webdirect with the same source.
E.g
With [manager] privilege set,
(FM15)  I could load the contract record within the whole department which assigned at table.
(WD) No matched record
With [salesperson] privilege set,
(FM15) & (WD) I could load the salesperson corresponding contract.
*  I could only found out that no Salesperson info. could be read / related to the contract layout, when the privilege set is [manager].
I would appreciated it if anyone could help.
