Problem with Email Module
I have just downloaded and installed FMSP 15 and when I try to send an email from the email module I just get Error 0 or to check my setup. I have tried to find where the email is setup but can't. Can you give me directions to set up my solution to connect with my  email program on OS10.12 and Safari.
Thank you
Hello Neil,
The email settings are located in the "Preferences" Module, which can be accessed from the home screen, or by clicking on the company logo in most layouts.
The "0" result is probably due to the default settings for the email being the free trial of the 360works CloudMail email plugin.
Simply go to the "Preferences" Layout, select the tab labeled "Email Pro" and the select either "Local Client" or enter your company's SMTP email settings.
Jonthan Hogle
