sliding problem
I have a portal that when I enter preview mode to print one row will collapse the row to about half the size, cutting off half the data fields. When I enter another row it's fine. This is not a problem on Windows, works fine, but on the Mac it does it every time with just one row of data.
Any ideas?
Thanks.
Print from the related table.
Not an option as I print 3 different portals. Besides, if it works on Windows then why should I have to redo it just to make it work on a Mac?
I've tried increasing the size of the area but doesn't matter, with one row of data it collapses the portal to half the height of the data fields in the portal.
