Two problems!!!!! Dos Problemas!!!!!
English
Hi, all
1)I have my DB with a some repeting fields, my questions is.
Can I paste the Current date, just with a click? or a tab? this is in a repeting date field
2)In the same DB I have a script to paste some information from 2 fields (pay, date) the script it's to paste this 2 filed in a last repeting field and when the repeting filed it's full send a message i.e.:
SCRIPT
Cut [select, "date"]
Go to Layout ["Payments"]
Set field ["Last(howpay)"]
Paste []
Go to layout ["oroginal layout"]
Paste []
Go to layout ["Original Layout"]
With this script doesn't work, you know something to do this.
Thanks alot for your help.
Spanish
Espa
The script you have described doesn't really do anything. A Set Field step needs two parameters. The field to be set and the value to set it to. The Set Field step in your script takes the last non-empty value in the field "howpay", but doesn't do anything with it. The Last() statement is useful in TAKING information from the last non-empty repeat not PUTTING information in the last repeat. To do this you will need to test each repeating field repeat and set the first that tests empty.
If(IsEmpty(GetRepetition(howpay,1)))
SetField("howpay"-1, "date)
End If
If(IsEmpty(GetRepetition(howpay,2)))
SetField("howpay"-2, "date)
End If
If(IsEmpty(GetRepetition(howpay,3)))
SetField("howpay"-3, "date)
End If
If(IsEmpty(GetRepetition(howpay,4)))
SetField("howpay"-4, "date)
End If
etc.
You might want to review the use of the Last() and SetField() function in the FM manual or using the built-in help.
-bd
I do it but how can I paste my information to the last field?
It's posible
When I paste, the information paste in all the fields
I'm not getting a clear enough picture of what you are doing to answer your question. The script I posted is how you would "paste" to the first open repeat of a repeating field. If this doesn't help, do you mean paste to the last repetition of a repeating field or the last record in a set? Paste to "last field" is not clear. -bd
