need help with message dialog question
how do you control the size of message box. on my xp machine it covers the whole screen.
Do you mean a Custom Dialog box or a particular menu option's dialog?
Hi, gurujee. What version of Filemaker are you using?
Besides the option to manually resize, this can also be controlled through the Windows Registry. In the Start>Run dialog, enter Regedit and click OK. Open the key [HKEY_CURRENT_USERSoftwareFilemakerFilemaker Pro6.0Dialogs]. In there, you will see about 11 subkeys. Play around with the values of the Bottom, Left, Right, and Top DWORDs in each of these subkeys until you come up with window sizes you can live with.
If the phrase "play around with the registry" is as breathtakingly frightening to you as it is to me Eeeeeek.gif, don't worry, i've safely messed with these values many times and changing them will not harm your computer.
HTH.
Jerry
Oh yeah--if you're using version 7, look in the key
[HKEY_CURRENT_USERSoftwareFilemakerFilemaker Pro7.0Dialogs]
instead. And if you're using Developer rather than Pro, change "Filemaker Pro" to "Filemaker Developer."
The subkey for the custom dialog is 5512, in case that's the one you're looking for.
J
Please update your profile to reflect the Platform, operating system and verion of FileMaker you are using. The link is just below you name in the box on the left, and is in blue "profile".
If you mean Dialog boxes, you can set them back to default size in Edit > Preferences - at least in 7. I have never used this because my dialog boxes have never been resized. But I recall seeing this option there. smirk.gif
Just checked vs. 6. It's in Edit > Preferences > Application.
LaRetta
this dialog comes up when i specify in a script. It only has OK or Cancel on it, just to tell the user what to do.
Thank You so much for your help
Thanks I just did. I'm new to this forum
LaRetta:
i feel so stupid. it worked. Thank You all for help
gurujee
LaRetta
