problem with relationship
I'm having a problem with a relationship. I have a layout with some info about hotels and a button that goes to the another layout that shows pictures of that hotel. I made a relationship between them with an ID field, and it work perfectly beside one thing. If I create a new record in the hotel table, it doesn't create a new one in the picture table, even though I selected "Allow creation of records in this table via this relationship". Does anybody know why this won't work? Thanks in advance
Selecting the 'allow creation' box is quite misleading for beginners. There are lots of people who think it does what you thought it did.
Unfortunately that is not the case. What it means is that you can create records in a portal and it allows a blank line for that purpose if the box is checked.
What you need to do is script a new record creation so that it creates the child record at the same time.
The script would be along these lines (assuming that you start from the layout for the hotel (not the pictures) and also assuming that your main records are set up for an auto enter keyID field
Create new record
Set variable to record ID
go to a layout that is set up to show records from the related file
Create new record.
Set key_id field to your variable
Go to original layout
attach this script to a button on your main layout and it will create related records in both tables
HTH
Phil
eheh thanks a lot! It's working now :
