Not able access WebDirect over WAN . Works fine over LAN
I have forwarded ports 80,443,5003 and i have checked to see if they are open .
FM server 13 is updated to the latest version .
I have a static IP also.
FM Go and FM Pro (Remote access from WAN) is working fine
Please help
Binu
If the situation is like you describe, it sounds like something is wrong.
However, I am pretty sure that either the port forwarding is not correct or you have entered a wrong address.
