FM9 and FM11 on same machine
I have FM9 installed on a machine. I now installed FM11 so that I can play with it. I still need FM9 in order to use my current applications. Once I installed FM11, I can no longer access FM9. ANy ideas?
I don't think there is a difference between platforms here, but on the Mac, I have several versions open most of the time.
If you open a file in 11, it changes its icon, and 11 becomes the default. However, you can always override this by opening the file from within the other applications. OR, choose the application you want by right clicking on the file. You can also drag a file on the Application icon of the version you want to open it, and it should open it instead of 11.
HTH
