FileMaker Pro 14v3, FileMaker Pro Advanced 14v3 Released
For those that haven't seen it yet:
http://help.filemaker.com/app/answers/detail/a_id/15295/
Software description
This software updates FileMaker Pro 14 or FileMaker Pro 14 Advanced to version 14.0.3.
Updater details
This software adds support for Microsoft Windows 10 and OS X El Capitan version 10.11, and fixes bugs.
Application
  • Windows: Addressed an issue where FileMaker Pro started slowly when certain firewall software was installed.
  • OS X: Addressed an issue where FileMaker Pro did not start correctly when the volume name contained certain characters.
Solution design
  • Windows: Addressed an issue where the Specify Calculation dialog box option "Validate only if field has been modified" became deselected after an auto-enter calculation for the same field had been modified.
  • Windows: Addressed an issue where, when a script was renamed using an input method editor (IME), the change was not saved.
  • OS X: Fixed an issue where scroll bars appeared prematurely in a layout window when the zoom control area was disabled.
Email
  • Windows: Addressed an issue where email messages did not include the expected recipients, and attachments were not sent. However, if you are still experiencing problems, see the FileMaker Knowledge Base answer 15190.
  • OS X: Addressed an incompatibility issue with Microsoft Outlook 15 where sending an email with an attachment resulted in an empty email body and no attachment.
